I don't even know if it's possible.
OK... You take a Cak which is all copper and electroplate aluminum on to the outside. Then you lap the bottom until you get to the copper.
Sinse copper conducts heat better, the heat will get to the fins, then the aluminum will radiate the heat to the air better.
I know nothing about electroplating, but perhaps someone does and has the means to try it.
