yep, i stacked two coolermaster fans, don't remember the models, dimensions if i recall are 50x50x10mm, rpm of these fans is 5400rpm. After stacking the fans the noise level did increase, but the two fans actually compliment each other as the rpm's on both have increased by between 400 & 1000rpm,the bottom fan is running at approx. 6250 - 6400rpm and the top fan approx. 5818rpm. Air flow with these has improved quite a bit too. Also my idle temp on the cpu is now 4 deg c above ambient, where as before was about 10 deg c above.
regards
