Has anyone tried to fit a 120mm fan on a....
nut
Do you know if a 120mm fan will fit on a SLK-800. I havent received my heatsink from the mail yet, so i have no idea how big it really is. And while Thermalright says that fits 60,70,80 mm fans. I thought i read somwhere that some people were able to get 120 mm fans on there.
If anyone has please share your experiences. Thanks
Maximouse
Toronto, Canada
I guess its possible if you can get an adaptor, most places sell them.
Gnufsh
Senior Member
Shasta Lake, California
I'm relatively sure that the adapters most places sell will not work on the SLK-800. An 80mm fan is actually a little bigger then the SLk-800 (in one dimension, at least), so fitting a 120mm fan would be hard. If you figure it out, I'd like to know.
Maximouse
Toronto, Canada
Could always mount the 120mm on the case and run a duct to the heatsink, or....theres always the Dremel and a creative imagination:)
N
nut
I'm sorry i said 120mm fan, I actually meant 92mm fan. But i guess from what i am reading 80mm is the way to go.
TerroH8er
I wonder how an SLK-800 would perform if someone fitted one of those 120mm delta 190cfm fans on it..
N
nut
That would surely be the ultimate in cooling.
190 cfm's on a SLk-800 = very nice frigid temps :)
f00t
just build yourself a shroud for the heatsink. I did for my Dragon orb 3 and attatched a 80mm fan to it. It is now wisper quiet and the cpu is still at the temps as it was before.
-f00t-
jlin453
Austin, Texas
Has anyone tested if a high output fan on the case w/a duct pointing at the heatsink performs better than the conventinal fan/heatsink combo?
wildfrogman
Sitting at my computer playing UT2004.
I have found that with the duct~funnel with the fan a few inches away from the heatsink you get a few C better temps than even with the case panel open. I think it has to do with the fan blades not being so near to the heatsink sort of like shrouds for a heatercore with watercooling. It allows the fan to work better but takes a little bit more time than just sticking the fan on the heatsink. Oh and with the duct~funnel just make sure to have 1/4~1/2 inch of space between the heatsink and duct~funnel for best performance As it allows more airflow than just stuck right on the heatsink.
drunkmonkey
Blacksburg, Virginia, USA
A nice fan adapterfrom plycon would do the trick.
I got one and 120cfm's on my AX7 seem to help the temps alot:D Actually, I could feel air moving BACK THROUGH the space between the fan blades and the casing, lol. 120mm fans are really the quiet solution. I get awsome cooling still with it 7V modded.
