- Sep 23, 2016
https://www.moddiy.com/products/PWM-1%2dTo%2d12-Fan-Splitter-Cable-(Sleeved).html
In my 10K build I will have 9 4 pin - 140mm fans - this cable which looks like it uses nothing but connectors I.E no electronics looks like it feeds 1 RPM signal back to the mobo which it uses to control the speed of all the fans which is what I want - taking power from the 5.25 inch power connector as opposed to the motherboard to power the fans.
I want to ensure that this can not damage the board as it's worth a grand by its self and that it will rev all the fans up and down at once which I believe it will. I have asked if they have a nine header version as well just for tidiness.
I'm referring to this as the "Pegasus Project" and you will see why when it's completed and I post pictures.
If anyone is using something similar for four pin fans I'd really appreciate knowing how your millage may have varied.
Cheers in advance.
Cheers in advance.
