Yeah, no kidding. Their chipsets were even crappier than their drivers. Even as I love my Nforce4 opteron duallie, Nvidia was nothing but a headache.Well they weren't very good chipsets to begin with, they almost always hit a wall before any P35/P45 did. Good riddance I say.
The most quirky issue I've ever encountered with an nvidia chipset was with my Nforce4. On a dual system, the nforce4 would blackscreen if you set the base clock any higher than 215mhz. You'd have to continue overclocking from windows via clockgen, and then you had to raise it 5 mhz at a time or the computer would hard lock. Volt tricking with the U-wire would somehow make the lan ports stop working.Some chipsets suffered voltage leaks which caused it to overheat really bad.
