Have an FIC case/PS combo. 350watt. Good enough for barton core?
st0rmshad0w
I have a case/powersupply combo I bought from tigerdirect.com
It's an FIC case and it came with a 350 watt powersupply. My asus a7v333x mboard supports up to 2600xp and barton core. If I go 2500xp barton, will my psu hold up and be stable?
thx
fiji
berlin
lots of times those generic psu's arent very good...
but it just depends on how many fans, cd drives, harddrives you have and if your going to overclock alot and stuff
but looking from your sig, if thats all you have on your puter id say its enough (but im not sure about ocing)
S
st0rmshad0w
thats all i have. im not going to OC the barton. I'm just wondering if it running at 333mhz bus is going to take more out of the psu
fiji
berlin
oh, if tahats all you got id say go for it
the extra 333 bus is the cpu not the front side bus of your mobo so you wont have to up the voltages
zachj
Chainsaw Senior
Redmond, Washington
The KT333 chipset supports 333MHz FSB. If you put a 333MHz chip in it and run PC2700DDR RAM, the entire computer will run at 333MHz, which means the FSB. The Barton and the newer XPs draw the same amount of power, so it shouldn't be a problem. And unless you have to raise the voltage on your memory, it won't require any more power to run at 333MHz either. If the PSU doesn't crap out on an XP, a Barton shouldn't be any different.
Z
