- Aug 1, 2002
- Michigan
AMD 5000+ Brisbane (not black edition) and no matter what I can do, I just can't get reliable OC'ing past 2.9GHz. At 2.92GHz Prime95 starts to complain of errors. Higher than that I get either BSoD or PC refuses to POST.
I have tried changing HT link from 1000 to 800, 600, and even 400 and tried changing multiplier lower (max 13x, wont go higher) and bumped the Vcore to 1.4 (won't go past 1.4) Temp didn't go past 42C idle and 54 load so it can't be overheating. I use 600 watts Ultra X-Connect Power Supply (probably using max 400 watts) and using meter I get 12.08v and 5.06v, didn't check 3.3v line.
I also tried loosening the RAM timing and tried the standard 5-5-5-15.
It's almost as if the CPU itself maxes out at 2.9. System spec in my sig below.
Attached a screenshot of CPUz of my current setting.
