Having Some Issues
bigtyme07
First off, I'm not entirely sure if the issues are being caused by W10 or if it's something to do with my components, but whenever I start my PC it automatically boots into the BIOS which I found strange, it started doing this after I did a fresh install of windows, also the log-in screen (the screen where you input your pin) lags quite a bit when I get there I don't know if this is standard but it doesn't seem to do it on my laptop. Just wondering if you guys could shed some light. Thanks!
Tír na nÓg
How old is the PC?
That occurs if the Bios battery (the one that looks like watch battery on the motherboard) is dead: the bios doesn't keep the settings, and acts like at first ever boot.
B
bigtyme07
Not old at all maybe 5 months, it's an ASUS ROG Maximus VIII Formula motherboard and it only started doing that immediately after doing a fresh install of windows 10. Could it be a driver problem?
dejo
Senior Moment Senior Member
could be uefi settings looking for legacy partitions or uefi partitions and not seeing what it is attempting to boot to
B
bigtyme07
Is there any screenshots that I could post that could help figure it out?
dejo
click on the "boot" tab at the top of the bios/uefi page.
scroll down to "CSM" and click on that
you need to look and see if "launch CSM" is enabled or not- if it isnt not- you may need to enable it. but document all your settings before making changes
see what option is selected in the "boot device control"- you should be able to select "uefi and or legacy"
find another tab "Boot from storage devices" and see what it is set to- could be "uefi first or legacy only"
another tab would be "boot from pcie device" with the same options
at this point you will need to hit "esc" to back up one page and scroll down to "boot options"
if you see anything labeled "windows boot manager" you will more than likely have to set the "boot device control" to uefi first
if you dont see "windows boot manager" you will more than likely have to set that to legacy only
trents
Senior Member
Make sure the boot order is correct in bios.
Also, did you delete the old partitions when you did the fresh install of Windows 10? You should do this.
shadowdr
Senior Member
Is it fully booting into the bios or just showing the splash screen and going into windows?
