- Jul 5, 2004
- Santa Ana, Ca
Well DM20 I ordered one too. Will test in WinXP and ME-II with my 3.9Ghz C2D both stock
and fully modded with ViperFang water.
Viper
Viper
ViperJohn said:Well DM20 I ordered one too. Will test in WinXP and ME-II with my 3.9Ghz C2D both stock
Viper
deathman20 said:Mmmm water, im just hoping the block I got fits on it since it. Otherwise I'll have a leaf blower for a while. And welcome to the club, but of course your 8800GTX will be more powerful, expecially at your insane clocks.
ViperJohn said:Oh making the WB fit is like a zero issue. It's no problem to machine the step in the base.
deathman20 said:Well for me not having a machine shop Might be a little hard. Are you going to make a custom water block for the whole setup or are you going to separate the memory/power regs and core? Curious because if you make something like that I might be interested.
Heating - A problem discovered
We have obtained, at the last minute, an IC thermometer with laser guidance, and we will be showing you these pictures in our future graphics card reviews. R600 vs. GTS vs. GTX (both single-GPU and SLI) thermal graphs will also posted during the week.
Yes, HD2900XT heats a lot. Does it heat more than Nvidia? Well, brace yourselves for impact, my dear readers, the answers might be quite surprising. In our testing inside the case, 8800GTX had a 100degC spot on the card. It was the very same spot that is heating like crazy on every nV card after 7800GTX (including the 7800GTX) - on the backside of the board, right close to the back of two 6-pin power connectors, we would see a 99-102degC spot. 102degC was reached inside a closed case after 1hr of 3DMark06 loop. MSI 8800GTS was also similar, and one spot at the back of power regulation was recorded at 92degC. Thus, seeing 88degC hotspot on the back of ATI card was actually surprising. We did expected 100 or so degrees Celsius.
Audioaficionado said:I'm also liking the capless VRM design a lot better. If they get that 65nm chip out with 1GB of memory, that would be something to really see. Better drivers for Linux would seal the deal for me.
dudleycpa said:All the 2900XT are now $430 at the egg:
http://www.newegg.com/Product/Produ...&Subcategory=48&description=&Ntk=&srchInDesc=
Weren't they cheaper?
deathman20 said:Zipzoomfly went up on there 2900XT Sapphire price as well $15 more but the order didn't reflect the change yay.
deathman20 said:Sapphire. I would of gone Asus but I don't see any one with them out. Im sure i can pawn my friends STALKER disk off him anyways.
dudleycpa said:The Asus card does look nice and STALKER doesn't hurt either.
Did you see the Sapphire Toxic version that is water cooled?
Audioaficionado said:An interesting note on that Inquirer review was that even though the 2900XT used more power, it didn't have as severe hot spots as the 8800GTS/X boards did.
http://www.theinquirer.net/default.aspx?article=39580
