- Jan 10, 2012
awesome lochekey, just awesome.
here's my helpSo I have been contemplating how to do the OCP mod and I am thinking about doing it slightly differently than what I have seen before. I am planning on building 2 bus resistors one rated at 450k ohm and one at 250k ohm. The ground pin from each of these will then be tied to a switch that is grounded. By toggling the switches I will have basically 4 different settings 450k/250k/160k/off. This should allow me to use this with various cooling methods without having the phases kill themselves. The only major problem I see with this is that there will be a constant 160k resistance between the pickup points on the card even when it is turned off. I do not know how this will effect things or if it will cause noise in the circuitry.
What does everyone think, do you see a better way of going about this? I am trying to avoid having to swap resistors out like Bobnova did, I will if I have to but wanted to avoid that extra socket if possible.
True that Blay!^ He's been rodeo clown for quite awhile now. Probably since the Peas and Carrots episode. LMAO
Would audio grade resistors (non conductive) help with that? If it's still a concern.
my gawd, lochekey, if you can see all that, you must be a teenager.
props to you for persistence buddy, keep at it.
I think Lochekey has gone full Rodeo Clown!![]()
Awesome Lochekey...can't wait to see it in action
Same here, hoping to get the 1800x on the benching loop. I will usually see 2c delta temps, so the loop should be around -4 to -8c.Supposed to be single digit tenors tonight. If I get home in time I will get it plumbed in and stick it outside to see.
