HD corruption
DaBigJ
Could 34.65 mhz pci speed possibly be bad for a hard drive? It's a DeskStar 60 gb hd model # IC35L060AVER07-0. Also, I have "enable write caching" enabled on it. Could that be a problem perhaps?
I am having problems with corruption. I am confident that it is not a virus. First, it was just the registry files that were corrupted, and I could replace those because system restore backed them up every few days. But just today, the file "ntoskrnl.exe" was corrupted and windows would not boot. I noticed that when I accessed a certain directory, the HD would make this funny, repetitive noise. The same noise I hear when a system file is corrupted and windows is trying to boot. Some files were missing from that directory (actually, most of them).
btw, I'm running WinXP Pro SP1
It takes about 38MHz before hard drive curruption will occour. But I'll let you in on a little secret. If you have a finiky ATA controller card, the controller card may be whats causing the curruption on the system.
OC-Master
finicky ATA controller card? more info plz. I don't have my HD controller in a pci slot. It's the onboard ide controller. Are those not affected by the pci bus? They should be affected, shouldn't they?
