HD Kaput, HEEEELP !
earion
I have a 80gb seagate and I to make 2 partitions out of it with Partition Magic 7 pro. Now when I boot, BSOD appears : Page fault in non-paged area.
What's going on ???? Please, i badly need help...
thx
earion:bang head
ronin1967
Highland Park, NJ
looks like you are toast...the worst part about using Partition Magic is having to reboot and hoping it works, looks like in your case it didn't, now you have 2 choices...
option 1:
you can remove the drive set is as a slave and install it on computer with a good drive to try and recover some of the data
or option 2:
format and start over
earion
earion
don't u think there's a way to recover the partition table or something ?
