- Mar 12, 2002
- Raleigh NC
In my search for the quiet system I have decided maybe to try watercooling my RAID array (2 Maxtor DiamondMax 7200's). I have found a nice high flow WB for this, but I have no clue how you would mount a WB between two HD's. Seems to me you have to mount one upside down (that should be OK, as far as I know) because its the PCB/spindle side that gets the hottest. So mount one upside down and the other normal with the WB in between. But what about the PCB? Will this large slab of copper cause a short? (I would assume so). So what can I put in between the block and the HDs to stop a short, but also still get good heat transfer? Thanks all.
Josh
Josh
