- Apr 3, 2015
- Planet Earth
Hello OverClocker Community!!!
First post here and I am newb at the modding game. I believe this is the appropriate forum for this question. I apologize if this is a rerun. If so please direct me to the appropriate thread.
So, I have learned that the mb pins for the hd indicator light runs at about 3v. I test mine and it jumps around a alot, obviously, but seems to peak up to well over 3v at times!?
I bought a three light laser LED:
http://www.newegg.com/Product/Product.aspx?Item=N82E16800888057
Cheap cool accessory I thought, not many specs on the manufacture side or the packaging though, just that it is 12v.
Hooked up the HHD indicator leads and nothing. Tried a 9v battery to test and it worked fine!?
( I have Y'd my indicator leads and tested all the connections)
So not enough volts?? Right?
I then saw this:
https://forums.ebuyer.com/showthread.php/40651-HDD-LED-on-mass-Tutorial
It shows using a 4N27 IC to use the HDD indicator signal as a on/off switch for a 12v power supply. Pretty cool actually, and would achieve the desired results for me.
But I a have a few questions. The tutorial indicates the possibility for a multitude of lights, but I saw somewhere that the IC has a milliamp rating limit and will burn out!???
So, what is the voltage requirements of a single LED and what milliamps?
Can I figure out how many LEDs can actually work.
What are the specs of the standard stock HDD indicator LED??
And finally, as the tutorial is a little dated:
Is there an alternative here?? Please! or maybe someone has made this into a nice little packaged component for the modding community.
Thanks for any feedback, it is greatly appreciated.
Great to be here!
Cheers!
I then saw this:
Great to be here!
Cheers!
