- Mar 17, 2002
- Raleigh, NC
Hi all,
Reading the "Flow Rate" thread got me thinking about some of the things I had learned from keeping salt water reef tanks in the past. As I mentioned in that thread, there is quite a bit of info. that can be applied from reef tanks to water cooling our systems.
One of the biggest complaints (for lack of a better word) I see getting posted is that many of you have been disappointed by the actual flow rate you are getting in your H2O cooling rig, even w/ that brand new 500GPH pump you just bought. While this has been touched on in earlier threads, it seems that alot of folks really don't understand just how important head loss comes into play. Most people do realize that overall tube/pipe length plays a role. But how many folks really understand that your choice of fittings, as well as the type of tubing/piping and how they are routed plays a significant role in determining what kind of flow rate you can realistically expect?
I'm definately no expert when it comes to this, but I have learned a thing or two. For example, whenever possible, avoid using 90's(elbows). In most instances, every elbow that you add will also add about 1' of head. It really doesn't take too many elbows to reduce your flow rate to a trickle.
Here are a few links pertaining to head loss and how to help overcome them:
http://www.reefcentral.com/vbulletin/index.php
(Fix a pot of coffee, and do a search for 'head loss'. Alot of the threads won't apply, but many will.)
http://www.reefcentral.com/calc/hlc.htm
(A head loss calculator.)
http://www.valler.com/fish/tips.html
(Head loss values for pipe & fittings, as well as a few good tips)
With just using the few resources above, you should be able to see how your flow rate has diminished significantly due to these frictional losses.
HTH
HTH
