I need some headphones that I can use at work for 8 hours a day at my desk and also take on road trips to listen to movies on the laptop.
requirements:
I have been looking at www.headphone.com. Some headphones that they gave high ratings to in my price range are:
These 2 are IEMs, but I dont have to have an IEM. Comfort is a must, and I have never wore an IEM so I do not know how I will like them. I was thinking of the IEMs because they are small and dont look like I am piloting an aircraft.
Also, I will consider buying a cheap amp (~$100) if it can be justified that it makes them sound $100 better.
So, do you have any advice for a headphone with my criteria? I listen to XM radio all day long, but sometimes the office gets noisy when certian people use speakerphone with their door open . Also, since I work at a locomotive remfg plant the test locomotive geta a little noisy too. These are both sounds I would like to block out.
requirements:
- comfortable
- noise-cancelling
- < $100
- best sound quality possible in that price range
