- Nov 12, 2001
Is it just me? Or have some the of rest of you "more observant" people always just tolerated it being called a "heat spreader"
It does nothing for spreading heat.
It's no more or less a heat spreader than the bottom of your Heatsink/Waterblock/Cold plate.
Really they should have just named them "anti-crushing plates".
Here are the points I see good and bad
Bad it's just one more place without perfect contact between the CPU and the heatsink. We use a thermal compound to help heat flow between the CPU and heatsink. They use nothing between the "heat spreader" and the core.
Good it's that much more MASS the heat can be absorbed to.(what two grams?)
Bad it’s not copper and therefore only impedes your nice copper base by that much more.
If you ask me they should have made it more of a shim instead of a "heat spreader". You'd retain slightly better heat transfer and keep the crush protection.
Rant Off
-Toysrme
Rant Off
-Toysrme
