is it possable the the asus a7133 mobo is reporting the heat wrong ?
with the asus probe my cpu is at 46c idle so I played Unreal tournament for about 30min heat only reported to 48c
very stable !! so it's got to be reporting the heat way to high !!!
I mean playing UT for 30min should over heat if I was having a heating problem
updated setup
asus a7/133
amd 1.33 ghz
taisol cgk760092 Ultra with a dap of Artic silver delta 80mm fan
pc133 cl2 256mb
80mm front case fan
slot fan cooler taking air out
so what do you peeps think ?
updated setup
asus a7/133
amd 1.33 ghz
pc133 cl2 256mb
80mm front case fan
