- Sep 10, 2002
- FL, USA
does any one know were to find a guide on how to make a shrod for a heatercore
grim said:hey nice shroud. so you are using those 2 tabs to secure the shroud instead of long bolts through the core? same thing i did.
and pop rivets to hold it together too. good choice good choice![]()
grim said:well thank you for choosing to use my design. yea i still dont have an article but i havent had the time (school). hopefully i will make one sometime and more people can use my design.
grim said:i used the sawed off edge of a 2x8 scrap.
Klownin79 said:Best way to make bending easy. Is to take a dremal and cut off wheel and go across the lines where you wish to bend it. Thats what I did and it was really easy.
MajinSSJVegetto said:How do you pop rivet things? I have no clue. Do you need special tools?
Would pop rivet go through .6mm steel case panels if I wanted to attach a shroud to my case?
