Heating up a Processor
The Unforgiven
Georgia
What is the best program to get a processor as hot as it can get? I'm running CPU Burn-in with error checking disabled and the most i can get is 5 degrees over idle. I'm testing the El-Cheapo $10 HSF and comparing it to the XP-120 and Delta Low Noise 75CFM fan I just got today. And perhaps I can get a few more mhz out of this 2.4A until I order my 630 and new mobo.
Vio1 said:
Whats wrong with Prime95? It has 3 options: 1)max heat 2) max ram 3) moderate
Nothing at all, I just can't run dual Prime95, because I do not have a hyper-threading processor. One instance of it would be stressful enough, and who knows what two would do. My guess is, absolutely nothing, or crash this beast. lol
so run one then :)
D
PS toast is also good
Just run prime95 on the heat test, gets hotter then cpu burn-in for me.
