Alright. I've been testing my cpu's temperature lately. From what I've seen I'm getting as high as low sixties at full load (Shuttle ak31 2.0 mobo reading). And I Idle between 44 and 50 (Depending on room temp mainly.) I've got a vantec CCK-6035D, with a YStech 26cfm on it. The heatsinks lapped mirrored (very mirrored). And although I'm currently putting more air circulation into my case, (case temps get as high as 42)... I doubt that will be enough, and I am looking at a few options. I'd like some opinions and suggestions please. Im really trying to decide between SLK800, and SK-7. Would there be any reason besides price to choose the sk-7? Is there anything better than both of those of which I am unaware? (No water. I'm not comfortable putting a tank of water into a box I drive around every other weekend, and I don't think I wan't to spend as much as a water system would cost anyway.)
Also, what fans would you recommend? I'm fine with the YS-tech 26cfm's noise, and I suppose I wouldn't mind a little bit louder, (of course the quieter the better,) but I could not stand the delta 38, I took it out within a week of installing it. So the fan would have to be less offensive than that. The main one I've looked at is the (edit) 'Panaflo' High output (32db, ~40cfm). Would that be enough cfm to really drop my temps or would I just be wasting 60$ buying a badass heatsink to strap a weak little fan onto?
Thanks for any help you can give me.
