Heatsink
stan03
If an slk was not an option, what heatsink would you get?
EDIT: for a p4
sirtoby
Finland
how come it's not an option?
well, anyways.. to get back to the question.. I would probably get something from Alpha or Swiftech instead then..
stan03
stan03
i said the slk is not an option because i knew the overwhelming answer would be them:D , and i wanted to know who else you might buy a heatsink from
n8x2
Alpha PAL 8045 or the Swiftech MCX that fits your mobo/budget.
Personally, I like 8045 over the MCX's:
cheaper
lighter
only a couple degrees dif (with identical fans/setup)
looks so nice (MCX's look kinda 'gimiky' to me. just my opinion)
u'v been here b4, haven't u? :D
sappo
guam
If noise is an issue, there's always zalman. my friend has a zalman flower and is so happy with it, he says he'll only buy zalman from now on.
arnoldma
Essex, UK
zalman r good or rather great when u run at close to stock speeds, but they dont hold up at all when u start to get into overclocking :)
edit: i'd have to say the Alpha PAL 8045 aswell :D
FrozenFears
Seattle
I use the SLK, but if I had to pick another heatsink, I would go with swiftech, I've actually thought about buying one and swapping it with mine to test for a change in temp.
stan03
stan03
hold up, i read a review on the CNPS 7000 and the only heatsinks beating it were the... *drumroll* SLK seris :eek:
