that sensor i believe is like outside cpu temp you could say, cause the internal temp of the cpu gets really really hot, but they base the "normal" temps on the mobo sensor and overheat temp, etc...cause if it overheats in the inside, then the overheat temp on the mobo will register as overheat too ;-)
