help? abnormal reading...
weponhead
maryland
um , i didnt know quite where to put this .. so i figured i'd ask you guys , I just put my 2 new fans in and i put my green ccfl in loose .. and its all running fine but now my temp sensor on my processor wont register anything but "NEGATIVE 128 C" anyone have any ideas on how to correct this ?
Odd. You've not made any other changes?
Can you give some more system info please? eg PSU make & rating, mobo, the software you're using to monitor temp etc.?
Try disconnecting one item at a time & see if it works (switch off before disconnecting of course). ie remove 1 fan, switch on & test, switch off, remove other fan etc etc
I am using a chieftec psu 340 Watts , hmm i was dissconecting things but never thought to turn it off to check .. i will try that now, and i am running 7 fans including hsu and psu fans and my ccfl is plugged in but not running, it sounds sometimes like i am getting power flux in the line because my new fan running at 54 cfm slows down and speeds up ...
