Help Backing up Raid 0 and what software to use
GMOOT
Hello
I have 2 SSDs each 450gb Total raid is 800 +
First Question how should I back up this raid 0 ? I have only used 120gb of the 800
I am using acronis true image 2017 But acronis backs up the whole 800gb .. Should I only backup the 120gb? is so how please
Any good recommendations on any fast software that can do some fast imaging ?? or any what ever you guys recommend //
Thank you
ATMINSIDE
Need to know more info... what OS? Is this the OS drive? What SSD's?
ATMINSIDE
Unfortunately PNY doesn't provide a backup tool.
That said, Acronis should give you the option to backup only the used space... how are you running it?
trents
Senior Member
Macrium Reflect is great for imaging. Has a lot of options for scheduling imaging on a regular basis, keeping a certain number of images, differential imaging, etc.
Janus67
Benching Team Leader
Do you hve to import any drivers into macrium to see the raid volume? What if you tell it to look at a volume instead of individual disks (I haven't tried that before, but there must be a setting like that)
GMOOT
GMOOT
- - - Updated - - -
Thanks for the reply I need help to fix this
Macrium will not do anything I keep getting this error
So I downloaded Driveimage XML and it worked it backed up only the 120gb
But now how to i fix this unformatted raid 0 i dont get it I formatted everything before installing :(
Janus67
Did you try googling the error message, did any responses make sense?
