CPU - i74790k
GPU - Gigabyte GTX 970 G1 Gaming 4gb 256Bit
RAM - Kingston Single 8GB 2133
PSU - Corsair Platinum 860 Watts
Motherboard - Maximus Hero VII
SSD - Transcend 128GB
HDD - Seagate 1TB
Newly Bought PC 2-3 Weeks Working then yesterday its not working fine cannot boot normally when i use restart command in windows 7
Beep Codes:
1 long beep then 3 short beeps - Video Card Not Detected
4 short beeps - Hardware component failure
I got a problem when i accidentally modify the settings in Dual Intelligent Processor 5 AKA "Al Suite III" of ASUS Software.
The story was I hear some noise in the PC i think the sound of the fans , then i check the Monitoring software "Al Suite III" it displays quite good temperature
CPU 32-35 Celcius, Motherboard 27-28 Celcius and GPU is cool at 24 Celcius then i discovered in the monitoring tool that the frequency is overclocked i got panic because i want to stay at stock speed which is 4000GHZ but It display 4400GHZ but the temperature is still in good shape 35-37Celcius even im using stock HEATSINK of INTEL , then i got panic i turned off all services include microsoft services and startup applications then i carelessly modified the Dual Intelligent Processor 5 aka Al Suite III i change something in the TPU i think i modify one of the cores there and set the ratio to 41 and forgot everything there. i discovered that the culprit is the POWER OPTIONS in CONTROL PANEL i change the HIGH Performance mode to balanced mode then after that it runs 800mhz in all cores but i did not set up back the TPU settings back to original form because i cant remember. how to fix the problem can i uninstall the Dual Intelligent Processor 5 "Al Suite III"? so the settings in the bios will be the one to get function not the software? first of all i did not change anything in the bios "EXTREME TWEAKER" i just only change the boot up setting for installation of windows 7 ultimate 64bit.
thank you very much and sorry for my bad grammar.
HDD - Seagate 1TB
Beep Codes:
