Help Building Budget Gaming Rig
Flappyd
Australia
Hey. I'm building a new computer for gaming i have a budget of about $700 AUD
I mainly play fps games and have been waiting for battlefield bad company 2 so i'd like to play that with decent frame rates.
also i was thinking of going for an AMD Build but it isn't necessary
Thanks in advance
WayOut
Seattle, WA
You'll need an AMD for the budget you're on. Lemme give you a setup.. 700 AUD is how much US?
650, according to currency calculator.
Umm, I'll work on something later. 650 bucks is a very, very tight budget.
F
Flappyd
Australia
yeah i am slowly getting more and more money i just dont have a job atm ill do a bigger upgrade when i get one i just need something to last me for now
F
Flappyd
Australia
i was thinking this might be alright
AMD Phenom II 550 $106
Gigabyte GA-MA770T-UD3P $106.50
GSkill 4GB (2GB x 2) DDR3 $125
Sapphire HD4770 512MB $119
Samsung 500G SATA II 7200rpm $67
Antec Two Hundred Versatile Gaming Case $65
Gigabyte Superb Power Supply 550W (not sure?) $62
Aopen DRW-2412ST SATA 24XDVDRW $33
Total $683.50
jgv115
Australia
Which part of Australia are you from? Are you getting the parts from MSY?
That is quite a good budget setup I would go with another PSU though, if you're buying from MSY then get the Seasonic PSR550+ it should do well enough.
jgv115
Australia
Which shop are you getting it from? It would help if you gave us names so we can have a look at their parts list.
F
Flappyd
Australia
I'm not sure i got the prices from http://www.umart.com.au/ even though they dont have a store in nsw but they could send it
there isnt much good stores round where i live (wollongong) but i could go up to sydney i just dont know any stores there
tinymouse2
Surrey, England
I would wait until you have a bit more money. Try 1000 CNDs before going for anything.
With 700 bucks you will only just be able to play MW2 on medium graphics at 30fps...
You'll have a dual core at about 2.4GHz or so, a 9800GT or something similar and 2 or 4 gigs of RAM. Up it to 1000 and you start to have a dual at 2.9GHz or a quad at 2.4GHz with a GTX 250 with 4 gigs of RAM. Up it again to 1300 or so and you can get a quad at about 3GHz with a GTX 260 or ATI equivelant.
This is in the UK but I can't believe it's "that" different in Canada.
jgv115
Australia
Well okay, I'm looking at the Melbourne Umart page and I see the 550VX which will suit you perfectly.
Corsair VX-550 ATX Power Supply 120mm fan PCI-E Graphics Card Connector 6 SATA Connectors Universal 106 dollars.
Definitely get that one even if it's a little more expensive.
