Help Choosing a Cable...
1Time
U.S. East Coast
Need a new SATA II cable to connect an internal hard drive to an ASUS P5NSLI LGA 775 motherboard. Which one should I buy from NewEgg? Thanks
Bobnova
Senior Member
They're all the same performance, being digital the signal either gets there and works, or does not get there and doesn't work at all.
The ones with metal clips are cool, some of 'em come in pretty colors which is nice.
1Time
1Time
U.S. East Coast
OK. So one SATA II cable is the same as any other except for the ones that have the metal clips to help them stay on more reliably.
I just didn't want to buy the wrong kind. Thanks again.
nd4spdbh2
Camarillo, CA!
ya sata cables are synonymous.
But i hate the cables with the metal clips.... i pulled the plastic socket off one of my sata ports on my P5W DH not long ago without even realizing it... till i went to plug in another drive about a week later and went... UMM WTF? i found the cable that i had used prior and sure nuf a lil orange plastic socket.... i was able to weave all the pins back through and snap it back into place thank god haha.
1Time
1Time
U.S. East Coast
I have to take it easy with the metal clip ones.
Now I'm trying to find out if I need a special power cable for this SATA2 hard drive, and whether I should get an SATA2 cable that incorporates a power cable. I will hold off on choosing until I can take a closer look at the existing cable and hard drive.
Theocnoob
Near Toronto Canada
I think you mean universal/identical. Synomymous would imply that they were actually synonymous with something else.
I haven't grammar-douched anybody for a long time but I figured what the heck.
:clap:
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
I think he is saying all sata cables are the same (synonym means the same)... which is accurate.
Anyway, not sure about the internal external differences, but get an internal in case.
Bobnova
Senior Member
External sata cables have more shielding, and possibly different connectors.
