- Jun 28, 2013
This is my first post, so cut a noob some slack...
I'm considering upgrading to an AMD Phenom II X6 1100T. It's on the "verified" list from ASUS, but I don't know if it's the best one I can get as a replacement (from what I've read, it may only run on 3 cores when not using 6, in which case maybe a quad-core would be a better choice).
I'm also wanting to upgrade the RAM and would like to run 4x2GB DDR2 @ 1066 MHz. ASUS QVL shows G.Skill F2-8500CL5D-4GBPK and Corsair CM2X2048-8500C5D as compatible with the MB.
First question: Is G.Skill F2-8500CL5D-4GBPI-B identical on the inside to the one on the "verified" list with the only difference in the heat sink design; is this model also going to be compatible?
Second question: Will I be able to stably run either of these at 1066 MHz with the AMD 1100T?
Alternate question: If I'm way off track, what is the optimal RAM and CPU for my system (can I stick an AM3+ chip in or can I get DDR2 1333 and downclock for better speed/performance)?
Sorry...I'm clueless...haven't kept up with parts since I built this thing a few years ago.
P.S. - How do I make this an auto-signature?:
MOBO > ASUS M3A79-T Deluxe, BIOS v.0302
CPU & Cooler > AMD Phenom X4 9950 Black 140W
MEMORY > OCZ, OCZ2RPR10664GK, 2GBx2
POWER SUPPLY > CoolMax CUQ-1350B
VIDEO CARD > ASUS EAH3650 SILENT MAGIC/HTDP/512M
HDDs/Optical drives > WD Velociraptor 80, Seagate 9EU142-310, No Raid
SOUND DEVICE > Onboard
USB > Usb Devices Plugged to Mobo?
O/S > Windows 7 Home Premium
Case > CoolerMaster Storm Scout
