I could use some help here. Any thoughts, ideas, or suggestions would be GREATLY appreciated.
My config:
AMD 1.2 GHz (266)(box) - not overclocking
Iwill KK266-R mobo using on board sound
256 MB CAS2 Corsair memory
Geforce3 (12.00) drivers - have not loaded "4 in 1"
60 GB Maxtor HD
56 k modem
Real Magic Hollywood plus DVD card
Ethernet card - disabled
OS: Windoes ME
Problem: My computer randomly locks/freezes - does not appear to be related to any particular program. When the program freezes I cannot reboot with Ctrl-Alt-Del. I have to turn the machine off, and then back on. This maneuver does not gaurantee succesful reboot. I will usually get a blank screen, although I sometimes hear the hard drive going through normal progression. I will then usually leave the computer off for a while, and then when I reboot, it seems to work fine, although Windows wants me to boot in Safe mode. A couple of times, when rebooting, The computer freezes during intitial power up, memory check etc. (on the initial Iwill screen). This problem has become progressively worse, and I can only get my computer to run a 2-5 minutes before freezing.
Thoughts: I wondered if AMD chip/Geforce3 chip(s) were overheating. Opened case to verify that all fans (4 total) are turning normally. "PC Health" in BIOS reports: CPU temp - 35C (have seen it up to 58C), system temp - 25C, CPU fan - 0, Sys fan - 0 (although I know both of these are turning normally), Vcore - 1.84V, 2.5V - 3.39V, 3.3V - 3.39V, 5V - 4.90V, 12V - 12.12V. Don't know if these are ok or not.
I tried installing Nvidia 12.41 drivers with self installer. Got an error. Then installed files by directing Windows where to look. This did not seem to help, so reinstalled 12.00 drivers over the newer ones. I did not do this in Safe mode, and I did not uninstall drivers before trying to install new ones - could this be a problem? If so, why would the computer sometimes hang during initial boot?
Along these lines, Geforce3 is on IRQ11 along with 2 PCI steering slots. In addition, the on board sound is running through IRQ 11 (2 slots). Should I (and how do I) force the interrupts?
Could there be a virus? I am running Norton System Works 2001. 3 days ago, I downloaded latest virus definitions and scanned the HD - clean. Ran Windows Doctor and found 45 errors - did the auto fix, and now freezing seems to be as bad as ever. Can't tell for sure, but I may have made things worse.
I am really struggling here. Hope you all do not mind me posting this info on this board, but I don't know where the problem lies. Please Help.
Thanks in advance
Trey
My config:
60 GB Maxtor HD
56 k modem
OS: Windoes ME
Thanks in advance
Trey
