I've got one of these "thunderbird approved" heat sinks from pcboost which is suppost to be good for up to 1.33Mhz. It has a pink putty like substance directly over the CPU, and acts as thermal grease. When I first installed it, everything is running just fine, the CPU temperature is around 40C.
Last night I decided to take it off in order to connect the L1 pins on my CPU. After I put it back on, the CPU temp shot up to 90C idle! I realized something is seriously wrong so I turned my machine off immediately.
So here's my question: how can I reattach the heat sink properly so that my CPU won't be cooked off again? Should I remove the putty stuff and go with some thermal grease? If so, what's the best way of getting rid of the putty? (it's kind of sticky and hard to get off).
