- Apr 21, 2001
- Augusta Twp, MI
I got the Red Hat Linux 9 Bible from my work for about $35 (reg. $50), which comes with all the CD's and about a million pages of instructions (good for use after you get it installed)... but they don't help me much with dual booting.
I tried using PM8's 'install another os' wizard- only to find out their boot manager is crap and won't install on ntfs. I installed linux, the installation worked, but Linux wouldn't load completely. After trying to reboot, I noticed that PM8 hid my winxp ntfs partition... so without recovery disks (which I didn't make- no fdd), I couldn't easily get back to windows.
So I reformatted (NTFS) and now I'm on a completely fresh install of XP pro. I'm going to give PM8 another try, but this time, I will only use it to split my current partition.
(n00biE) Questions:
After I split the partition in PM8, then delete the new partition (unallocated), will Linux automatically use this unallocated part of my disk (and create it's own partition and format it and install itself to)?
And if so, will I need to use any third part boot managers to switch between the two installations, or does linux and winxp have their own boot managers? I don't want to get stuck with a non-working linux, and try to get back to windows only to find out that I can't.
Thanks!
(n00biE) Questions:
Thanks!
