- Nov 29, 2013
- Groningen
Hey guys, I need some quick help. I was looking to get more performance out of my system so I did a bit of reading. I saw that if you injected thermal paste into the 24 Pin motherboard power connector and also into the cpu socket and the power connectors the video card itself it will cool better and it will up my frames. So, I did that today and for some reason there is a red LED light where my cpu is and it says CPU, I referred to my Motherboard manual and it said that it indicated a bad CPU basically, Could I have damaged my System? Here are my Specs, CPU: Intel I7 4770k @ 4.0Ghz, PSU: EVGA NEX 1000, GPU x2 SLI'ed Geforce Gtx Titans, Motherboard: Asus Sabertooth Z87, SSD: OCZ Vector 128 gb, RAM: Kingston Hyperx Predator 2400 MHz. Case, Azza Genesis 9000. Thanks alot Guys!
