Hey guys, I am really stumped on this "finding the correct mobo" deal. I am building a new computer with no "left-overs" from previous PC.
Basically, what I need is this:
all for under $100.
The closest that I can find is: Biostar TA790GX A3+ Ver. 5.x (AM3, DDR3 16GB, CrossFireX 8x/8x), but the website shows only support for up to Phenom II X4 (no 6-core). Biostar-SME website DOES have a BIOS upgrade to support X6 (link), but I don't know if its reliable.
Also, the mobo doesn't seem to be marketed in my country (Indonesia), as I could only find Biostar TA790GX 128M which is an AM2+ board and goes with DDR2 and CrossFireX 8x/8x, but doesn't support Thuban X6 (even on Biostar-SME, I can't find a BIOS update for it),
and Biostar TA790GXE 128M, which support X6 based on Biostar-SME (but not on biostar.com.tw), DDR2 and CrossFireX 8x/8x, BUT sports only AM2+ socket. (which would be OK, if Bulldozer don't support AM3, which I'm still unsure if it ever will).
The upgrade plan:
I am planning to use Athlon II X3 440 for the CPU, as it is enough for me right now. I will do some OC, to push the X3 to its limit with stock/cheap (~$20) cooler. And would like to unlock the 4th core (if I'm lucky and get a working core).
My plan is to upgrade next year to Phenom II X6 1055T/1090TBE with better after market cooler, or even Bulldozer (if AMD releases an AM3 version).
The questions are:
Thanks for taking the time to view this thread and pardon the bad english
- Socket AM2+/AM3 with support for Phenom II X6 (Prefer AM3)
- DDR2/DDR3 support up to 16GB/32GB (prefer DDR3)
- CrossFireX 16x/16x or 16x/8x or 8x/8x (Prefer 16x/16x or 16x/8x)
all for under $100.
The upgrade plan:
The questions are:
- Do you guys know any other/better alternatives for under $100?
- Will Bulldozer ever support AM3 socket?
- Do I need DDR3 if AM2+/AM3 will only support up to Phenom II X6? (because I'm planning to max out the RAM next year, therefore no need for future proofing).
- Is CrossFireX 8x/8x good enough for two ATI Radeon HD 5770? Because I heard 16x/4x will only results in 25% less performance vs 16x/16x. No idea for 8x/8x.
- Will the BIOS' of the boards mentioned above/the alternatives support OC-ing the Athlon II X3 440 CPU (including ACC/Advanced Clock Calibration) and unlocking the 4th core?
- What is the difference between GX and GXE on said Biostar boards?
- Is it true that Biostar TA790GX A3+ and TA790GXE 128M will support Phenom II X6 with a BIOS update from Biostar-SME and the TA790GX 128M won't?
- Say the Bulldozer CPUs won't support AM3, would AM2+ boards be good enough for Phenom II X6? What are the disadvantages of using AM2+ for X6 instead of AM3?
