- Feb 25, 2004
- MA, USA
I'm trying to help my fellow Aw8D and Ab9 users. I have a hunch its certain ICs that don't work well with those boards. so if you guys could give me a hand and check to make sure I have the right ICs listed from the righ ram, and Id some unknown ICs for me. Also if you use those boards, and could list what you use that would be great too
I've got a hunch that the reason overclocking doesn't work too well on this board is due to the Bios not liking certain memory chips. So if you can OC fine on this board post your memory maker, what ICs, BIOS version
If you don't know the chips (IE under a heatspreader), post Unknown and I'll do my best to try to find what they use.
If you completely clueless download CPU-Z and go to the SPD tab. That will give you all the info expect for the ICs. Bios Version can be found in the Mainboard Tab in the BIOS Section, on the third line titled Dated. 3/20 is V11, and 6/07 is V12
Tony, the OCZ rep over at XtremeSystems.org believes its either the Award BIOS or the Board bios that is causing incompatibility. He believes is the Award BIOS and that the board bios needs to be rewritten in order to fix the issues. But this does not explain the ability of some people being able to hit high speeds and others not, which leads me to think its certain ICs. He intends to test OCZ modules with the AW8D and the AB9 Boards next week. I'll be watching the thread he creates at XS as well as the OCZ forums and will post any findings here.
Doesn't Work Well
Guide
Make
Model
IC
Bios
FSB
Muskin DDR2 PC2-4200 2x1GB
Model 991338
ICs Elpedia Recertified 5-5-5
Bios V11
Limited to 237FSB
OCZ Gold 2x1GB PC2-6400
Ics Unknown - Removed from IC
Bios Unknown
Limited to 237FSB
Corsair XMS2 PC2-5300
Model Unknown
ICs Micron (Possible D9)
Bios Unknown
Works to 300FSB
PQI PC2-7200
Model Unknown
ICs Unknown
Bios Unknown
Works to 300FSB
OCZ DDR2 Value Series PC2-4200 2X256
OCZ DDR2 Value Series PC2-4200 2X512
OCZ DDR2 Value Series PC2-4200 2X1024
Ocz2/533/1024/pfdc-k(2x512) 3-3-3-8
OCZ DDR2 Gold Series PC2-4200 2X1024
ICs Value - TSOP
Gold - Unknown No markings on ICs
Bios V12
Limit to 215FSB
Kingmax PC2-4300 1GB
KLBD48K-A8HD4-HCAS
Hynix Chips
Bios V12
Limited to 240FSB
PCI Turbo PC2-5400 2X1GB
PQI25400-1GSB
ICs Unknown
Bios V11 and V12
FSB to 300FSB
