- Nov 2, 2001
- Tulsa Oklahoma
I remember a post about how someone couldn't remove their processor from the socket because either conformal coating or dielectric grease had sealed his socket. I'm having the same problem, I can't remove my processor from the socket and I used conformal coating around the socket and inside the center. I also used dielectric grease in the pin holes.
Can you help me find that post? Can you give some suggestions?
Is there a better way to prevent condensation that won't lock in your processor?
Thanks
Arch5
Thanks
Arch5
