- Dec 26, 2000
- Baton Rouge, LA
K, I did the voltage mod on my A7V about a month or so ago and everything was going great with my [email protected], but I got a new 1.1GHz t-bird, and it decides that it decides it doesn't really like the voltage mod (maybe the connection got compromised or something, I don't know)...plus, it didn't want to overclock at all
and it was giving me stability problems
So I figure on just clipping the added 24kOhm resistor and using the normal A7V voltage...well, I didn't have any wire clippers on hand, so I decided to just use a pair of scissors (big mistake)--apparently my soldering job on one of the points was really sturdy (really really sturdy) and when I clipped the resistor, it jarred the SMC resistor it was attached to out of place (the one closest to the actual motherboard)...crap!--oh, and it broke in half too
Well, I didn't realize this until after I restarted my computer and got nothing but a few beebs of death. I don't think I fried the processor because the current was unable to run to it (I guess anyway, I'd like to think that my new processor still actually works)
Anyway, does anyone know where I can get a replacement SMD resistor for this board?
If you need a visual aid, check this out from tomshardware (the one that broke is circled on the bottom)
If I can't repair it, then I guess I'll have to get a new motherboard...
I was thinking either the A7V133 or KT7A--what do you guys think...
P.S. I'd like to try to fix this motherboard first
