Doing a full tear down of my loop after around 2 years of use, using 2x EK copper GPU blocks, EK Supremacy Acetal/Nickel CPU block, D5 pump, de-mineralised water and a silver kill coil (no dies or additives), 240 and 480 HWLabs SR1 radiators. Loop has been refilled twice in that period with new water.
The (presumably nickel) plugs in some of the EK components looked to have corroded somewhat since they were put in, their surface being very rough and no longer shiny, the Nickel CPU block also had some obvious discolouration - in some places all the way down to copper below the plating. The copper GPU blocks when last disassembled had some mild discolouration, partially removed by just rubbing with some wet paper towel. None of the Bitspower 'silver shining' fittings showed any meaningful signs of corrosion.
After flushing out the rads, there were some very tiny 'dark' particles in the water - so small it seemed more to affect the colour of the water than being clearly visible particles.
Image too big to embed:
http://imgur.com/aeaUlIG
This residue and paint bubbling is on the bottom of the end tanks of the 240 radiator at the lowest point in the loop. Does this look like a pinhole leak due to corrosion? There was no signs of water residue on the case or fans, or around the fittings on the opposite (upwards facing) side, and the inside of the end tanks look pretty normal.
Any help would be much appreciated as I plan to re-assemble everything in the next few days.
