nope...no flashing light on the floppy, but the HDD light stays on......hhmmm..apparently, the bios i used IS correct...hhmmm.......the thing is, i do it correctly....ill outline exactly what i did, and you can say where i went wrong...
1. Downloaded the bios file...it was a self-extracting exe.....i put the extracted files in a folder called c:\windows\desktop\flash\
2. I then shutdown into ms-dos mode and went to the directory where the flash was.
3. I ran the .bat file which executed awdflash.exe with a command line option to use the new bios.
4. I confirmed i wanted to flash the bios, it did it, with no evident errors, then it returned to the command prompt.
5. I switched my comp off, then switched it on.....switches on, but nothing else.
does that help?......surely i did it right?
