- Apr 10, 2001
- Wichita, KS
When you try the hot swap first remove the orignial Bios chip and then reinstall it so that it is seated and all pins are making contact but not pushed all the way in (so that it will be easier to remove while the comp is on). I have also heard of using nylon fishing line woven though the pins of the chip you will be removing to give you additional leverage to pull the chip.
Good Luck.
Good Luck.
