- Sep 29, 2012
- Fresno, CA
OK, this is a bit of stupid question. Using Windows 7 Ultimate, how do you install a new hard-drive? Last night I wasted several hours trying to figure this out last night and got absolutely nowhere.
I have a WD 2TB Green drive, that I assume is not formatted. It shows up in the BIOS during boot with the serial number and size, it shows up in Windows under the Device Manager as one of the hard-drives, but I cannot do anything with it, it is just there in serial number only. I also tried to access it by a Thermaltake Blacx USB Dock, but it only shows up as a drive (without a drive letter designation) that I can choose to safely disconnect.
I also tried to enter Dos, but was unable to, I guess you cannot do that any longer in Windows 7 (e.g., command.com)?
I cannot figure out what I am missing. The only thing I can think of doing at this point is making it my boot drive and running the Windows install disk to see if windows will run on it, presuming that this will not cause any problems later when reformatting it, e.g., Windows locking directories, hiding files, etc.
Also to note, if this has any bearing on the issue I use an eSata connection for 4-WD RE4 500GB in RAID10 on a Sans Digital RaidTower for my only hard-drive.
What I am trying to accomplish is to temporarily install the WD Green as a spare drive so that I can transfer everything over from my current system to a new PC I am building (as I am not planning on using the external eSata RAID configuration at this point).
I had even considered placing the WD 2TB into the RaidTower as the fifth disk, but thought that it would either (A) just become apart of the array or (B) cause issues with the array because it is a different sized hard-drive.
