Help! Iwill KK266-R, Doesnt do anything???
stompah
Deep Pain Senior Member
I have installed all components to my new Iwill KK266-R. I press the power switch... Nothing! No spinning of the PSU fan at all.
Could my front panel switches be connected wrong?
Layout on MB:
24..12
23..11
22..10
21...9
00...8
19...7
18...6
17...5
16...4
15...3
00..00
13...1
00 denotes no pins
function........................PIN #..............definition
PWR_ON......................1,13
ACPI (LED)...................3,4
ALED (ide LED).............7,8...................#7:anode, #8:cathode
RST (rest)....................11,12................#11:RST, #12:GND
PLED (power LED).......15,16,17..........#16:NC, #17:GND
SPEAKER......................21,22,23,24.....#21:VCC, #22:GND, #23:NC
#24:SPEAKER
Wires from case:
S/B SW:..........Green/Black
Reset SW:......Black/White
Power LED:....Green/White
HDD LED:.......Orange/White
Any help? Am I connecting these right? (not like I shared that with you) Could I have a bad PSU? What is your setup on this board? Why does this always happen to me? (dont answer the last one please )
PS everything is plugged in, the PSU is set to 110 and there is power to the outlet.
thanx!
Looks like you have every thing right do you have the heat sink fan plugged in to the correct header and does it have the Third wire for RPM? if it doesn't the board will not start at all. Check this and see if it helps The fan header is the one just below the CPU and to the left of the north bridge.
Yeah all is setup right but it is nice to have a working PSU! So I canniballized a 300w from another case ;)
Now time to figure out why it isnt recognizing my WD 400bb HD?
