- Nov 2, 2003
- Miami
Hello Guys
I am trying to built a sort of ram air intake for my CPU.
What I am planning on doing is connect a pipe (or Tube) to the current CPU fan and go straight to the side of the CASE.
What I manage so far is to use a small plastic tube to the heat sink and then "taped" another fan to the end of it. the only problem so far is making the hole to the case and comming up with the proper FAN. I am using a regular 40mm Case fan, but I am wondering if it has enough "umph" to biult the presure in it.
I left the original Heatsink/fan in it so is runninng with to fans...
I have seen a kit around to take air from the fromt of the case, but that is too long of the path, and air would aclimate to temps in case.. I want a straight shoot into the CPU..
Any ideas?
Looking for the proper FAN.. I am going to Home Depot Today
to buy a PCV pipe 3" diameter/ 4" lengh... need to make a bracket
to attach to the heat sink/ and another to attach to the side of the case( has to be removable , since the side panel is remobable..
Running
Gigabyte 7N400 Pro
AMD 2700+
213 FSB X 11 Multiplier
temps at 43C with the 2 fans
Any ideas?
Running
Gigabyte 7N400 Pro
AMD 2700+
