- May 8, 2004
I'm looking to upgrade to the "upper echelon" of cases, and Lian Li is at the top of my list. My main PC (PC#1 in my sig) is built in an Antec SLK-3000B. I really like that case, but I need more room for my Video Card (any newer video card hits my 6 HD's ) and more HD Bays. Yes this is a wordy post for a friggin' case, but this is a $250-$300 investment so I think it is appropriate . I'm looking to buy tonight if possible, so I'd REALLY appreciate any quick feedback from the lovely OCF Community
So - primary needs are:
I've been racking my brain over 3 different Lian Li cases - 2 Mid Towers and one Full Tower. I really like the Full Tower's spaciousness and 6x 120mm fans ( ), but the height of almost 24" (2 feet!) will be hard to fit under lots of desks IMO (It won't fit under my current desk, but I might get a new desk eventually). Anyways here are my 3 candidates:
PC-A70 Full Tower (I LOVE the space, cooling, and 10 HD Bays ):
http://www.lian-li.com/v2/en/produc...133&cl_index=1&sc_index=25&ss_index=61&g=spec
PC-V1010 Mid Tower - New Design! (I like the 120mm Chipset cooler):
http://www.lian-li.com/v2/en/produc...209&cl_index=1&sc_index=25&ss_index=62&g=spec
PC-A17 (I would need to add a second HD Bay to have room for 6 HD's):
http://www.lian-li.com/v2/en/produc...135&cl_index=1&sc_index=25&ss_index=62&g=spec
So, the Full Tower A70 is my fave from a cooling standpoint, but again I'm worried about the size (will it fit under a standard type desk?). I really don't need all 5 5.25" bays, either (I only need 3 TBH). The 10 HD Slots are also a plus...
The V1010 is a brand-new design (no reviews on NewEgg yet) and it's looking good and appears to have plenty of room (not too tall), but I'm a bit concerned about cooling with only 1x 140mm intake down low (for the HD's + PSU). The MoBo/CPU section doesn't really have an intake, just the "Mid-Plane" Chipset fan and the rear 120mm fan. If you guys think the cooling is adequate on this one then it will likely win my vote! I really like the styling, too!
Lastly, the A17 is like a higher quality Antec 900 IMO. This has the PSU up top like a regular ATX Case (the other 2 cases have PSU's on the bottom). This one also adds a 140mm TOP fan! The one drawback is I would have to buy an extra HD Bay to have room for all 6 HD's - this would also add a second 120mm intake on the front! So 2x 120mm intakes, and 1x 120mm and 1x 140mm exahust! One of my concerns is Video Card clearance with 6 HD's in there. I think I might be in the same boat I'm in now with my Antec SLK-3000B PS - Do you know where to get extra Lian-Li HD Bays for this unit?
Last point - Are the Lian Li fans any good, or should I replace them all with Scythe FDB versions?
Thanks so much! I can't wait to be able to replace my old X800XT video card with my new 8800GTS in whichever new case I get!!!
- Holds 6 HD's with good airflow (more HD slots are welcomed)
- Room for a long video card (8800GTS) with all 6 HD's in there
- Good airflow in general for an OC'd q6600/Ultra120 and chipsets
- Good wire managment
- Not tooooooo big, but roomy
- No front door
- Clean, uncluttered appearance (a given with Lian Li )
