After days of trying to sift through all the info about different heatsink configurations, I'm giving up--I need some help! Here's what I'm currently running:
Celeron 2 [email protected][email protected]
Abit Slotket!!!
Soyo 6BA+IV
Golden Orb
Radio Shack Thermal Paste
I'm currently idle @ ~24 celcius, maxing @~45 under normal workloads, up to 52 or so if I TRY to heat up the cpu.
I have yet to put on the cover to my system since getting it up, so I expect that when I do, temps will raise a bit more.
So, here are my questions; first, given those temperatures, do people think I need more cooling? I know this chip has a lot more in it, but I don't know if I can realistically get it any higher because my harddrive doesn't like pci bus speeds above 38mhz, but I would, of course, love more speed if it could be had.
If I SHOULD get better cooling, I have a couple of dillema's, first, using this Soyo board, I have minimal clearance to the DIMM slots (~2 3/4" from the cpu to the end of dimm 2). Soyo recommends filling DIMM number one when bus speeds are above 100mhz, anyone have any thoughts about that? If I can safely move the ram out farther, I can sacrifice at least one, maybe two dimm slots, as I doubt I will move much above the two 128mb dimm's I have now anytime soon.
I also have clearance problems towards the top of the slotket!!! The golden orb is currently coming in contact with my power supply, so I need something that does not protrude more than a cm or so above the top of the slotket. The golden orb is 69mm in diameter, so I need something no wider than that. A tall order, no doubt! I've been trying to figure out the dimensions of many of the popular coolers out there, but not having too much luck finding detailed diagrams, or at least ones that give me enough confidence to order something I can't return easily! If someone has any recommendations for me, it sure would be appreciated!
I guess what this long winded post boils down to is that I need something that doesn't protrude above the top of the slotket, that will block out no more than 2 dimm slots (and the fewer the better) and will give me substantially better cooling than I have now. All thoughts appreciated. Thanks!
Abit Slotket!!!
Soyo 6BA+IV
Golden Orb
