Help me choose parts
Sp3wn
Ok I'm going to "attempt" to build my own water cooling system for my barton 2500. These are the parts I've narrowed it down to (not much variety as I live in canada) I want to use 1/2'' id tubing and I want it to be a quiet. Any help on what parts to get would be appreciated
CPU wb: swiftech mcw6002-a, tdx, or rdx
Pump: Mcp600, mcp650, mcp350, and eheim 1048.
Rad/hc: http://www.e-compuvision.com/shop/?...&category_id=c086d8894a13b1cc088d78a1c8e30470
if this hc isnt good enuff Ill try to find something at an auto parts store around my house.
I would ditch that rad for a 2-302 or 2-342, Both are all copper(unlike that Alu heatercore) I've got no athority to say that those cores are less restrictive than that one, but they sure as heck are cheaper. ^_^ (2-302 is ~$17.99 USD)
As he said ^^. You would be better off getting a core for a 77' bonneville and modding it. Its simple to do and doesnt take much time. Itll work better than the one you posted a link to as well as it will be cheaper.
Don't forget your T line and such.
You'll also need a T fitting and tubing, and start looking for a cap for the end of the tube.
7
Ok Ill try to find a heater core locally, but what about the cpu wb? I'm pretty much set on the mcp350 as it is the most silent.
You are missing what can sometimes be a key point. A 2-302 is the heatercore for a 77' Bonneville WITH air conditioning. Sometimes that makes all the differance....
Well I wouldn't use the Eheim 1048 cause it doesn't have very high flow(it's like 150 GPH). I also wouln't use that rad :eh?: Go for a heatercore or a Black Ice Xtreme or Black Ice Xtreme-2.
Mississauga, Ontario here (45 mins from Toronto)
What kind stores can I get one of those heater cores from?
CanadianTire , Napa , John's auto parts. Look in teh yellow pages , I live in Brampton like 20 min from mississauga :p SquareOne owns :)
ok I'm going with the lucite tdx, eheim 1048, 1/2'' idclearflex, hc w/ 2 silverstone 120mm fans. I want to build my own res but do u constantly have to fill resevoirs up with water or is it like a t-line which is air tight? cause I dont want to keep refilling my system every week or so.
is the ddc that much better than the eheim 1048 or 1250? cause its going to cost me $102 for the mcp350, and like $50-60 for the eheims.
