Help me!! component come off from my 9800 pro
fujin
the half purple and half silver component by the right hand side fan's screw come off form my 9800 pro.what does that purple component do? what happen if i don't solder it back? would i get a decrease in perfomance?
Mr B
Senior Admin Emeritus
East Bridgewater, MA
Please do not double post things throughout the Forums... Multiple identical posts will be deleted.
Mr B
Forums Moderator
Gautam
Senior Benchmark Addict
SF Bay Area
Yeah, I break caps off my cards all the time. It got to be a near everyday thing with my Geforce4 (something was truly awful about that card's design). Just take a little bit of solder and solder it back on.
But don't even think about the running the card without it.
F
fujin
i am not use to soldering things .is it easy to kill my card???what thing do i have to take care of while soldering???
The Coolest
Senior Member
If you're not good with soldering, or don't have much expirience, I'd take it to an electronics shop, or ask someone who can solder, to solder it back on. Its much safer that way.
L337 M33P
TEH INTERNETS
What The_Coolest said.
If you aren't used to soldering then I don't recommend you attempt a repair yourself. If you still have the capacitor then take it and the card to virtually any electronics shop and ask them to solder it back on.
gbaz
New Orleans LA.
Me thinks they are probably right. I did not know what i was doing and was able to get the thing suadered on, but why take a chance if you can get someone else to do it for a few dollars. Or if you dont mind taking the chance of loosing the card go for it :) I would. Think of it as a learning experance ;)
