Hello patron saints of computing!
I've lurked around here for a long time (and learned a lot of useful things), but I finally feel compelled to ask for help, as I am upgrading my PC for the first time (previous machines, um, died of cooling problems; this one still runs fabulously) and am confused as to how to salvage my data/programs/OS.
Years ago when I was a poor student, I bought a Cyberpower machine (before reading all the negative reviews. I wouldn't do it again, but mine ran great!) which came with Windows 7 Home Premium 64-bit pre-installed, so I have a license number but no disk.
The machine looked like this:
Xion Predator AXP970 Gaming Case
Intel Core i5 760(2.80GHz) (quad core)
4GB (2x2GB) DDR3 1333
1TB SATA-II 3.0Gb/s 7200RPM HDD
450W power supply of a brand I'd never heard of (since replaced with a Corsair CX750; this is actually too much output; it's down in the inefficient part of the bell curve, but my PSU had died, and this was at the time my only machine, so I was limited to what was in stock at the local Fry's because I needed my machine to work again. And I was consumed by brandlust and a dramatic rebate. But mostly the needing my computer to work immediately).
ATI Radeon HD 5450 1GB PCI-Express Graphics Card (since replaced with an NVIDIA GeForce GTX 750 Ti)
24X DVD±R/±RW Dual Layer Drive (no burner for some reason. I could buy one, I guess, if it would make anything easier)
All in a very strange motherboard that only has 2 RAM slots (and no details on the receipt, other than the fact that it has an Intel H55 chipset).
As you can see, it's time to upgrade the processor! Which also means upgrading the motherboard and RAM. (Buying an SSD will have to wait; all my money is going into overhauling the rest of the computer.)
I'm thinking of buying:
Intel Core i7-5930K Haswell-E 6-Core 3.5GHz LGA 2011-v3 140W (which seems to be about as much processor as I can afford)
ASUS X99-A motherboard
CORSAIR Vengeance LPX 16GB (4 x 4GB) 288-Pin DDR4
You can critique the build if you like, I haven't bought anything yet, but my question is actually: Can I use the Windows 7 license from my current machine in the machine it's going to be turned into? (ie. uninstall Windows and then reinstall it? Do I even need to uninstall and then reinstall it?) How? This isn't an OEM license like you get from Dell, is it? Where the license is tied to the motherboard? What do you recommend for bringing my programs over to the new build? They're all digital licenses (except the Microsoft Office Suite, which has actual disks I can use) so there isn't any physical media, though there aren't very many of them. Music/pictures/documents have an obvious solution. I worry a little about game save data, but Steam is pretty good about putting that kind of thing in the cloud where it can just be re-downloaded.
What say the lovely men and women of the Overclockers community?
