Help me design my 2000$ dollar loop for my 3500$ pc. Build Log will come.
youngcolieo
Hello, and thank you for looking at my thread. I built a custom pc and thinking of upgrading to water cooling in a bigger and better case. I will post pictures as soon as I am done to show you guys the results. I am wondering what you guys think of my build that I will make.
Here are the main parts:
Case: Phankets Enthoo Primo: http://www.phanteks.com/enthoo-primo.htmlhttp://www.phanteks.com/enthoo-primo.html
Processor: Intel 6700K CPU: http://goo.gl/gm9dA6
Graphics Cards: EVGA GTX Titan X super clocked: http://goo.gl/emtaq0
(and yes there are two titan x's that wasn't a mistake)
Motherboard: ASUS Z170 Deluxe Motherboard: http://goo.gl/CDs9W2
Ram: Corsair Vengeance DDR4 Ram: http://goo.gl/M6zinq
PSU: Corsair AX1200i PSU: http://goo.gl/8WRnca
SSD: Intel 750 PCI-e SSD: http://goo.gl/N0aohe
Custom Mods/Cables: http://goo.gl/ZR55qM
Water-cooling Parts:
Rads: 1x Alphacool NexXxoS XT45 Full Copper 480mm on top (push pull)
1x Alphacool NexXxoS XT45 Full Copper 360mm on bottom (push pull)
2x Alpha NexXxoS XT45 Full Copper 240mm, one on front, one on side.
1x Alphacool NexXxoS ST30 Full Copper 120mm on back
Pump:
XSPC D5 PHOTON 270 RESERVOIR/PUMP COMBO
Help Me find another pump since I will have so many rads plz, preferably D5
Liquid:
3 PrimoChill Pure Intensified | Performance Coolant (32oz.) – Clear
Tubes:
PrimoFlex Advanced LRT 1/2in. x 3/4in. Tubing (18ft pack) - Pearl UV Green
CPU Block:
Help me find one, price doesn't matter just keep it under 200$
GPU Blocks:
Help Me find some too, keep each one under 200$ as well.
Fittings:
I have no ****ing clue. Please help me find some as well.
Obviously this is an extremely overkill build, and it would be awesome if you guys could help me find what I need to find. I will be posting build log as the build progresses, as soon as I get the parts. Obviously I am looking for a black and green build, but tell me what you think. Also any led strip suggestions would be epic.
Thanks for helping me out!
