- Feb 13, 2001
- Twin Cities
I'll give you the "Kmart" answer instead of the "Neiman Marcus" answer. ;D
This is "Trickle Down" regulation. The PSUs hardest challenge is to regulate the +5V output. It accomplishes this by varying the chopper drive to the transformer primary based upon the load on the +5V output. The +12V output shares this drive also. When demand on the +5V goes up, the drive goes up to accomodate it. Consequently, the +12V drive goes up also. That's why you hear the fans, running on the +12V speed up slightly when you load the CPU.
You need to place a nominal load on the +5V to get the drive pumped up to accomodate a large load on the +12V. Personally, if I was using a PC PSU to power a Pelt, and I might mention that I would not, I would put more like a 10A load on the +5V, not just a 1A load.
If you want the "Neiman Marcus" explanation, email me. It will take a page or two to explain Pulse Width Modulation Regulation.
Hoot
Hoot
